Removal of relay
nevilledoreen
GEELONG WHICH IS 45 MILES FROM MELBOURNE AUSTRALIA
1993 300SL R129
I have a 1993 R129 300SL the light globe check light on the dashboard keeps coming on at random I have replaced the rear number plate globes as this can cause the check globe light to come but it still comes on.
I have been told that it could be a faulty relay I have removed the cover to the relay but I can not pull it out of its socket is there any trick to withdrawing the relay from its socket ?
Can anyone advise ?
Regards
Neville
There are a lot of pins which make it very tight, it takes a firm grip and a pull straight up wards.
There is, I think , a lever on top which has to be pulled out of the way, this lever may assist in the units removal.
Your problem may also be a dirty contact at the bulb holder or the wrong wattage bulb being fitted.
Dec
Picture source… 1991 Mercedes 300SL R129 24V Light Control Unit ECU 1295420032 | eBay
Is yours like number 3 in picture?
Dec
