There is a screw in the wheel arch just behind the liner. If you loosen this screw the side strips come out and reveal the centre rear strip.
You work from the sides toward the middle.
You can remove the whole bumper but it is a bit of a pain.
Just be sure to remove the screw that is for the bumper strip and not the one that keeps the bumper close to the bodywork, although you may need to loosen that one.
do you know if removing the centre strips will be enough to fit sensors
read somewhere else easier to remove whole bumper
also you say screw in wheelarch, do you have to remove liner for access?
thanks
thanks
- remove spare wheel cover
- remove rear plastic on trunk sill
- remove all of the trunk lining
- remove 2 main bolts holding bumper in place
- remove several smaller bolts holding bumper close to the bodywork(4 IIRC)
- remove two small bolts in wheel arch holding trim close to body
- dismantle trim pieces
- install cable
- install new trim piece with sensors
- clip in sensors
- remove grommet from bodywork
- pass bumper wiring into grommet
- test before installing bolts
