Removing front seat belt from a 05' e class ????
knockerblip
Hi Anyonewho can help...............How do you go about removing a seat belt from within the pillar on a 05' Eclass?? I can't see an obvious way to get inside the trim
Any help will be gratefully received......Cheers
The pillar trims are held on with clips , these clips can be seen when the sealing rubber is removed . Pry the clips off from the car , its easier than uncliping them from the pillar cover
