thebook
Afternoon,
My AirCap wind deflector across the top of the windscreen doesn't work properly. One of the retaining pins (used to hold the deflector down securely) has broken. The symptoms initially was a failure to retract, but now it gets caught on one side when raised.
I have come to the conclusion the whole system needs to be replaced (I would have preferred just replacing the pin, but heyho).
Does anyone know how much labour a switchout requires? Has anyone had this done? Could I just cut off the pin? I have a 2011 cabriolet, an A207 I believe...
Thanks in advance.
Thanks in advance.
