Reverse assist passenger mirror dip
BaldGuy
Berkshire, London & Devon
No longer a Benz...
When I reverse my passenger side mirror used to dip down so I can see the road, Just recently it goes up instead of down:(
In other its back to front.... whats going on??? The cluster is configured for it to dip. I have turned it off and then back on but it still does it.... Any ideas????
Sounds like it needs resyncing. It is thinking it is already as far down as it can go when you engage reverse and it powering it the other way.
No idea how to do it though , but we both know a man who will .... ;)
Wifes did this a while ago and i still havent got around to looking at it!
Just switched it off on the dash
Lynall
i have almost the same problem my mirror does not dip down far enough just tilts closer to door but not down,also do not fold in when i turn engine off eventhough its set to do so
Whilst in reverse gear adjust the mirror to the desire position.
Make sure that the vehicle is stationary and that the key is in position 2 in the ignition lock.
Press button
for the exterior mirror on the front-passenger side.
Use adjustment button
to adjust the exterior mirror to a position which allows you to see the rear wheel and the kerb.
Press memory button M
Press one of the arrows on adjustment button
within three seconds.
The parking position is stored if the exterior mirror does not move.
If the mirror moves out of position, repeat the steps. You can adjust the exterior mirror again after storing the setting.
make sure that the vehicle is stationary and that the key is in position 2 in the ignition lock.
press button
use adjustment button
press memory button m
press one of the arrows on adjustment button
if the mirror moves out of position, repeat the steps. You can adjust the exterior mirror again after storing the setting.
i tried with engine on and off but it still does not go all the way down. When i push arrow down the mirror stayes still but if i pushed any other arrows mirror moves-my shifter was in reverse position
any other idea??
Thank you
You don't need to be in reverse. That said I think the problem is with the mirror. It seems it is already at the limit of travel downwards.
You could try by hand gently easing it back up?
Ok
The mirror can actually tilt much lower when i adjust it but after i do and then turn engine on and put toreverse it just tilts about a half way.it also moves briefly--(jiggles) at one place like it wants to move but it does not.i tried even with shifter in park position.
Thank you for trying to help me with this-maybe i am just a little slow thinker--haha ha ha...
I think it shoul work the way you r telling me it makes sence
i will try again
where are you from?? I see this is uk web i live in texas usa but i am from the czech republik originaly so my spelling might be incorect ok
thanks again
bohous
Do you know it only works if the mirror adjusting switch is switched to the passengers side.
Alan
i will try again
thanks again
bohous
I'm in the UK, don't worry your spelling is better than some native Brits! :)
I have checked a US owners manual and the instructions are the same as for UK cars
What catches people out is the last instruction, to press the mirror adjustment again within 3sec. If the mirror moves the memory setting hasn't been stored and you have to repeat the whole thing!
Perhaps the adjuster needs a little lubrication? Try folding the mirror and spraying some PTFE dry lube into the rear of the housing (don't go mad, you don't want to flood the mech!)
BTW don't forget to select the left mirror at the mirror control switch.
Mine only works if the switch is selected.
allright i forgot you drive on the left side of the road we here in usa on the right a little detail so on my side i must select right mirror.but it still does not tilt all the way. a friend told me today to disconect battery i will try it maybe tommorow if i ahve time.my mirrors dont even fold in after i turn engine off even it is preselected
i also have problem with tape player :it keeps openning doors and than it closes and than open every 3 seconds.when i put tape in it will play it for 3 sec/then eject it and on a display writes --tape error--so the tape door is open and i cannot see the display to set navigation .....bla bla bla...any ideas???
anyways thank you all for not giving up on me and for your help
Bohous
Bohous
Phone a priest.
I DO NOT TRUST TO PRIESTS:bannana:
