Felstmiester
- Jul 17, 2013
- Range rover sport
Picked up the c63 last week and was given the oem reverse camera and told all the wiring was in the boot ready to hook up. Done loads of searches and found many threads about this but can't find out exactly what I need to.
The wires are in the boot and I have switched on reverse cam via secret menu. But when I select reverse I get the black screen with check all surroundings. I then got a please wait message with a moving sort of buffer looking circle witch stayed on the screen for ages. I left it and went back to it around 20 mins later and it still said please wait. I then turned off the ignition and back on and then just got black screen with check all surroundings but nothing else.
The camera I have has got a red and yellow RCA, the red plugs into a cable that runs to brake light live and ground and the yellow plugs into a yellow male RCA that comes from front of car. The yellow male also has a small red wire that branches off that I assume is another live but not sure if this needs to be hooked up as when I plug the RCA in and live and ground to brake light that's when I get the check surroundings screen.
Any help would be great. Thanks in advance. Dave.
