jimbu
Folks,
Please help if you can.
My car has been running well with a new MAF for a few weeks. The previous one appeared to fail gradually and the replacement I fitted brought the car back to its usual stunning performance.
I filled up with diesel the other night and a few miles later the car started running erratically - misfiring etc.
The next morning when I started the car it emitted a large plume of white smoke from the exhaust pipe and was idling very roughly. It eventually smoothed off and ran better but the rev limit has been kicking back in at 2500 rpm again.
There are no warning lights or error codes showing on the dash.
Upon cold-starting the car seems to run normally. As soon as the engine heats up a bit the revs are limited, gear changes happen at lower revs and generally the performance stinks.
Has the new MAF failed? Is there any way of bench-testing them easily?
Cheers
Jim
Cheers
Jim
