Yeah the other side is the same :/Air bags on the rears , is the other side the same ?
The front has been lowered because it was very high when I got it and the rear is air suspension yesS211 means estate.
Tbh the rear looks ok, the front looks low. I'll compare to ours later when Mrs Me returns from gathering the Guinness tokens.
As said, on the facelift post 2006 at least, these have rear air suspension.
Have you checked the front springs haven't popped?
Nope, the rear is air suspension the front is springsHad it had a coil spring conversion?
Yes it has beenHas it been in for repairs recently, on one of them garage lift things?
I've got Airmatic on both front and back, every time it's serviced or MOT'd, I get it back and it appears to be sitting higher than before it went in. After a while it appears to settle back down to it's original stance. I'd assumed these garage lift thing were extending the airbags and after some time they revert to their normal positions?Yes it has been
It's been a while since it has gone on the lift but it's the lowest it goes naturally it doesn't settle lower :/I've got Airmatic on both front and back, every time it's serviced or MOT'd, I get it back and it appears to be sitting higher than before it went in. After a while it appears to settle back down to it's original stance. I'd assumed these garage lift thing were extending the airbags and after some time they revert to their norma
I thought it was sitting higher than normal?It's been a while since it has gone on the lift but it's the lowest it goes naturally it doesn't settle lower :/
It is higher but it doesn't go down lower on itselfI thought it was sitting higher than normal?
Ok, mine usually takes a week or two to settle down.It is higher but it doesn't go down lower on itself
