hi all
i have a 1991 300e that stalls when i stop at junctions etc
it only happens when the engine is up to temperature
it idles at about 750 rpm in park but drops down to 500 rpm when in gear
i removed the idle actuator and found that the valve does not fully shut is this correct
should there be voltage to the actuator all the time the engine is running
i found that if i unplug it the engine stalls
it as the bosh ke jetronic injection system
is there a way to adjust the idle speed
if anyone can suggest other parts that may be causing the above and tests to carry out i would appreciate it
thanks in advance
chilled
thanks in advance
chilled
