Rubber replacement help
gototravel
viano
Hi, anybody knows where to get the rubbers around the door frame? Those on my Viano are aging, everytime can hear metal knocking sounds - door hitting the body panel. Thanks in advance
The obvious thing is to ask a dealer parts department but I would ask a retail (car) dealer and a commercial dealer because the Viano will have the same parts as a Vito. Worth asking because a lot of official parts aren't as expensive as you would think. For commercial parts, I can recommend this outfit who will deliver and have are Ebay sellers https://www.sbcommercials.co.uk
If they are expensive, the next obvious thing would be to locate a set of rubbers from a newer (but the same model base) vehicle from a breaker W638 for up to 2003 and W639 for 2004 onwards.
Check your door hasn't been bent/twisted out of alignment as the hinges aren't up to a lot!
