Run flat inoperative, see owners manual.
Pedrostar88
Wick
C Class
I have the run flat inoperative and ABS currently unavailable…. Message on w204 C class. I have connected iCarsoft and got the fault code C113200 - the signal of component L6/4 (right rear axle RPM sensor) is unreasonable . Also codes I have replaced both front ABS wheel sensors in the past. Does this mean there is a problem with a rear sensor. I cleared the failt with the iCarsoft and the message disappeared but it returned within 30 seconds of driving.
Looks like one could trust iCarsoft in this particular case.
Am sure it is wheel sensor , had exactly the same in both my E class and my ML
You might find an issue with the reluctor ring or abs sensor on the rear.
