Rust SEC
Pav560SEC
560SEC
Hi All,
i have some rust coming through in my 560 SEC, under the back window and in a couple of the arches.
does anyone know a good Bodyshop in east London to take my car to,
i was gonna go to Jags Body shops
thanks
pav
I had the 560 rear parcel shelf dreaded rust when i had my 560.
It might be in the wrong direction for you West Molesey,near Walton -on-Thames.
I have used Vanleigh for over 20 years and Ron & Lee are experts on Classic Mercedes and did my Parcel shelf problem with great effect and looked after it on many occasions. The do a lot of restoration work especially on Mercedes. Give them a call 0208 7831212. if it's not to far. Mention my name Peter O'Neill and they will look after you.
Cheers Peter,
I will give them a call,
wil have to take the car around over the bank holiday to a few garages and get some quotes
The actual parcel shelf part is no longer available and hasn't been for some years, it was a single part that made up the rear seat upright and parcel shelf and was circa £1000 10 years ago when they were available.
However there is a repair panel available for the base of the rear windscreen from mercedes. It wasn't expensive when I last bought one about 3 years ago.
As for wings, simply change the fronts for new, the rears have repair panels available also. These were circa £300 a side from mercedes 3 years ago.
Remember that 560 front wings differ from 420's and 500's in so much as they have a slightly wider arch.
If the rear screen is good then keep it but renew the rear rubber and trim when you get the rust repaired.
All good advice.
