OK, so these modern canbus etc. cars. I have a universal bypass relay TEB7AS, can I just wire that to the rear lamp feeds in the normal manner? I'm led to believe that this is required (the relay) due to it upsetting the car otherwise and leading to errors if it's driving 2 bulbs where there should only be one. I assume the load of the relay is small enough not to register.
Also any hints and tips on best place to pick up the wiring so as not to run wires all over the place. There are lights in the tailgate and on the rear corners...
