Seal at top of cls W219 is allowing water in
IFFY100
SCOTLAND
Cls 350 cdi 2010 grand edition
As the title says, the seal has failed. The windscreen is original and I would like to keep it that way. The seal is allowing a small amount of water through. What would you guys suggest I do?
Contact a glass company who can remove and refit.
where bouts from the windscreen is the water leaking in from and where does it end up? as in do you see it clearly around the pillar trim or does it pool off in the carpets?
