side chrome moulding/trim badly pitted on s class 2014 can it be repaired
gary1707
ne64nw
s class mercedes 350 2014
Hi
side chrome trim bottom of all doors badly pitted can they be repaired or do i need buy new ones. if replacing are they easy to take off and replace.
hope someone can advise
gary
Similar issue here:
Better in the long run to buy a new one. Given you need to take the old one off to whatever to it, pitting will return.
You may be surprised how cheap they are. I say once you have a new one fitting will become clear by looking at the back.
are they easy to tyake off
Similar issue here:
thanks will look at
You see how they fit and take off once you have a new one in your hands. I guess 2 screws each end in the inside of the door and then clips into the door. Cant imagine them being hard at all.
This has been covered before in the forums and as mentioned you may clean them but it wont last and you will need to take them off to clean. At that point replace.
