Go to a mercedes main dealer armed with your registration certificate and photo ID and they should be able to order a replacement lock to match your existing key.
The link was just for illustration of the part, I’m not suggesting you buy from the US, when you add the shipping costs and UK import duty there wont be any savings, as suggested earlier, bring your VIN (vehicle Identifying Number)to your local MB dealer.
Or order on line as Howard suggests in his link. Just noticed that you are in Malta, do you have a Mercedes-Benz dealer in Malta?
Dec
I will try the link....yes we have a local MB dealer but it will most probably cost more here & take forever!
Trying to get in touch with MSL also.
What part of the unit is actually leaking, have you considered a repair with some kind of rubber seal?
Typical rubber membrane below, the one in my picture is off a W202, if you attempt to open the diaphragm be aware that the White plastic is extremely brittle and easily broken.
Dec
Ah so, its somebodies else’s problem, and the have to put it right.
Dec
