SL350 (R231) manual lift boot struts
David44
Land of the Prince Bishops
2013 R231 SL350
I have the original ones still fitted and would like to know how high the boot lid should lift, at present it only raises about 8 inches and the rest of the way up needs manual assistance.
Seems a bit feeble (not that I have a R231 to compare).
On my 10 year old (at the time) w203 hatchback, I needed to replace the boot struts for the same reason, and I see you car is around that sort of age now.
It was an easy job with an assistant to take a bit of weight of the boot lid whilst I changed the struts, one side at a time.
It was pretty inexpensive as I recall, at about £15 a strut, and just a small flat blade screwdriver and some long nose pliers. 10 minutes tops.
Maybe these? £37?
Magneti Marelli GS1201?
Maybe these? £37?
I did buy two new Stabilus struts last year and to be honest they made very little if any difference. There are versions of the same original part number according to the weight of the lid.
Maybe these? £37?
Just looked at the link and you may be on the right track for a solution, these struts are rated at 635n the ones I bought were only 580n
It doesn't sound like alot of difference between the two makes, but more generally both of those figures are a mind blowing amount of force for opening a boot lid.
If we roughly translate into kgs, that's 63kgs of force, which seems incredible to lift a lid a fraction of that.
So I guess if we look at the alleged difference, 63.5kgs vs 58kgs (using rough 0.1kg to the N) is a 5.5kg difference. I'm assuming the effort required to lift the boot is next to naff all, so maybe a tiny bit more oomph on the strut would do it?
On my 231, when I open tune boot it doesn't raise at all, just unlocks, I have to lift it up completely by hand.
I'm no Engineer, but as the son of an Engineer, I'd say you've got two choices.
Either live with it. (Old Engineering tradition - if it's working, leave the ruddy thing alone)
Or replace it for correct OEM spec - whatever that actually is - and see if it gets back to what you remember. Cost is tiny and it's easy to fit.
On both my R230's, the boot lid certainly didn't bounce wide open like a saloon when released. From memory it just slid gently up.
This post! Mine isn't a trebuchet when opening, just glides open with some light assistance from me..... of course mine could also be on the way out!!
