SLK 230k space saver pump
mark1962
Poole, Dorset
SLK 230K
Hi
I need to find a replacement space saver pump for a 2001 SLK 230k. I have looked at buying the car but the pump is missing and need to get the garage to replace it. A part number would be great.
Mark
Hi Mark, I assume you are referring to the compressor pump that normally comes in cars with no spare at all. It is not a space saver wheel/tyre pump. I have the set in my 2006 CLK Sport and would assume that it would be the same for the SLK.
Compressor part number is A 000 583 07 02 and the Cannister used to seal the tyre is A000 583 12 12
Hope this is of some help.
If you have a space saver spare, I don't know why you would want this kit. I expect it will be expensive.
Regards Ian
You could try pinging an email to [email protected]
or call MERCMAN PARTS ENQUIRY on 01736 757777
They may have the prerequisite Compressor you need.
Give him the part number as provided by ingin: A 000 583 07 02, the cannister is probably a long shot as they have a definitive life, though a similar tyre sealer can be bought from Halfords, Motorbitz or such like.
You maybe in luck and get the compressor at a snip. :)
