spacesaver
tobus10
Huntingdon
2000 202 est
A silly question!! I have lost my spare wheel well (lpg Tank) so have purchased a spacesaver spare via ebay!! It is new unused from a 203 so will fit my 202 est fine..now for the silly bit,if I ever have to inflate it and use can I then deflate it back to its original size..I wish to get a bag made for it.
Jim
Yes you can do that,, my spare has to be deflated before it will fit into the recess
the 202 and the 203 both use the same bolts, but do check the length of the bolt,, when in the hole there should not be more than 18mm sticking out of the rear
One assumes that you carry a pump then, which most people do not??
If you do deflate it make sure the tyre seal is not broken as a normal pump will not reseal it, it need high pressure.
