speed cameras on sd card
alzieboy
over the Rainbow
E350CDI Coupe
I had the speed cameras downloaded on a sd card, I removed the card from the command slot to put in a music card, now when I want to put the sd card with the speed cameras on back into the comand slot the speed camera files will not load to the comand (Ntg4.5 )
Any help please :dk:
I'm assuming you have tried to reload them again as Personal POI's ?? I know that if you take the SD card out the nav stops recognising the `poi's and you have to start again.
Apart from that I don't really know........delete the files and download a new set and start again from scratch!!
Hi Mate
Yes did exactly as you say this morning, but with no luck command system will not load PersonalPOI files
On the Command unit ntg4.5 is the sd card reader the same for Audio and for Nav, as a Audio sd card plays okay but as per my above posts the unit will not read the sd card on Nav set up for PersonalPOI (separate cards used)
