Spring/shocks/strut qurey
Madaboutbush
London
Mercedes e220 A207
Hi I've just gotten rid of the run flats and added a new set of MPS4S, now I just need to rectify the ride quality/suspension. It's a tad on the hard side, could anybody recommend which is the best way to go in terms of budget. I can't afford bilsteins ATM so thinking about adding springs to the struts if that's even a possibility. Also would it be best to replace the struts at the same time? Car is a 2015 A207 E220. Thanks in advance chaps
The 207 came with sports suspension, what are you proposing to make it better ??
Unfortunately, it's easy to make a car's suspension harder, less so to make it softer.
1 thing I do know is the sports suspensions top priority is based on performance and handling, not comfort.
I know . I sold mine for some comfort. Running on 19's with very little rubber wasn't good . Ok if you drive motorways , unfortunately I don't .
