Sprinter 313 w906 eml throttle bodies code limp mode
Daddymac79
Lancashire
Sprinter 313 w906
I have a 313 w906, over the last 2 months its had an intermittent flashing eml after reading the code i found it related to throttle body valve i believe they can fill with oil and end up grounding out causing the eml, however i took the engine cover off and noticed that it had rubbed through one of the fuel pipes on top of the filter so my guess is the diesel has dripped down to the connector on the throttle valve causing a ground to occur , can anyone show me the location of the throttle valve or let me know if its possible to clean the connector from below.
