Dkw
Hi I have a merc sprinter 311 2.2 2001
Has suddenly lost power. On investigation I found the turbo actuator was faulty all vacuum being released via the breather. Replaced this but no change. There is no live to it at idle and turbo not kicking in. If I put vacuum direct to turbo there is an improvement. But hit a hill and slows down badly. It has no maf or egr only a map sensor which I've replaced with a new genuine one. Only code that comes up is fuel enrichment fault. It's also rev limited to 3500rpm while driving. Has anyone else had this situation?
Thank you any input would be greatly appreciated
