thanks for the replies lads, apparently the carb was cleaned and re set just before I purchased the car, I'm not really wanting to go down changing the carbs etc, just subtle things like if there's a direct replacement better exhaust/intake manifold? Or air filters? Thanks
Inlet manifold & air filter change I doubt will give you any gain. So, if it's just subtle changes I'd go:
1. Tune up on a Rolling Road, making sure the engine is good along with getting actual BHP & Torque figures.
2. Fit modern retro Electronic Ignition.
3. Fit a freer flowing exhaust.
4. Electric fan with adjustable settings.
5. Fit an engine undertray, if not fitted currently. 6. Low rolling resistance ECO tyres along with 7.lighter wheels. 8. 20-30mm lowering springs. 9. Smaller more modern alternator. 10. Smaller lighter battery if possible. 11. And keep as much 'junk' out of the car when practical. 12. See, if the cold air feed an be improved to the air filter housing.
It all adds up. If you managed just 1% gain on average just for the sake of this exercise from each item above: power, less weight & better aero, you're looking at a total gain of 12% (I'd hope to see that from just items 1, 2 & 3). All in all, there should be improved power, MPG, driveability and handling.
