SRS Code AD52
MTotanji
Sweden
C180
Hey guys.
I have W203 MB with SRS light in passengers seat.
I bought SRS emulator to turn off the light and after i had it connected under passenger seat and tried to remove all codes so it showed up a new code that i couldn't delete.
The code is AD52 control unit N2/7 defected. the obd2 device i use is Maxsys Autel.
Any help so i can get right coding info for this type or i have to do something else ?
Thank you guys
Regards
Does this help?
Does this help?
Thank you for your reply,
Its not related to this code AD52 but i guess i have to use Xentry to try restore SRS settings to default settings.
I will try to get Xentry and will write if i could sort the fault.
This one perhaps?
BTW, Xentry is essentially MB STAR diagnostic computer. An independent specialist will have it.
