Srs light
ducatiboy
Hi guys can anyone help
The other day I cleaned car out
I moved seat right back and now the srs light comes is on .
Yes you may have a faulty seat sensor
Or loose electrical connection under seat
If you get a start test done then you can get the codes and erase fault codes and replace the right part if needed
Could also be wiring plugs under seat come loose
