Srs light!!
kdlma123
w168
Hello everyone I'm new on this site having just bought a 2000 w168 2weeks ago.
Problem already with srs light but I think I've sorted out the problem,
Anyway what happened was I've found the power steering fluid was low so I've topped it up and turned the steering left and right a few times to bleed through when I finished the srs lit up so I went to investigate with the steering wheel and found that the clock spring had been snapped and chewed[emoji26] so I've replaced it with a second hand one it works cos the horn hoots now but the srs light is still there!
Now I want to ask you experts, do I need to go to mb to have the srs deleted are should it goes out on its own after its fixed
Kind regards
It will need the codes erasing.
Search for a specialist near you. No need for a main dealer. There is a section on here that may help.
I'm thinking of buying a decoder icarsoft980 anyone got one of these looks good on website and YouTube
Is it good?
Just a couple of pics to show you guys what could happen when you turn your steering wheel left and right full lock
In can't believe how this can happen!??
