will this make the air bag detonate at all... or will it be ok to drive ?
and thx for reply pammy
Shouldn;t do - should do the opposite - if the light's on it won't go off.
Just a note of caution - make sure you rectify this problem before the next MOT. In theory, you car willfail the test because of this. Reason is that the safety system of your car is impaired.
so .... if i just remove the srs bulb in the instrument panel it'll be fine?
Not if you need it..
I've just spotted the OP's car is >10 years old. There is an urban myth that once a bag is >10years old it needs replaced and there is likelihood it won't deploy in an accident where it should. I know my old mans 993 is due new bags soon as I read in its idiot guide that airbags need replaced every 10 years ago.
the interval was extended i believe.
