However, I think the material itself does have a bearing on the noise: it's thinner than mild-steel equivalents.
It's also stiffer so has a higher resonant frequency so tends to ring whereas a mild steel exhaust will dampen the sound due to flexing.I think the reasons it thinner is because for a given section its stronger than steel so doesnt have to be so heavy (hence the tinny sound) and also i suppose as it doesnt corrode they dont have to factor that in.
Which is good as it makes it less brittle and prone to heat cracking. This must be used for manifolds. It's dependent on how much chrome there is in the mix.Do a google but iirc theres stainless and theres stainless some rusts!
