Hi guys
New on here and hoping to solve.
Mercedes W204 displaying esp and abs lights on dash.
MB have said: esp light on dash req scm replaced and coding.
What does that mean
The car had a recall for earthing inadvertent driver airbag deployment and they picked up on the esp and abs warning lights on. Which have been on since last week.
Could it be steering angle sensor or scm
Chances are there's a problem with the steering angle sensor which indicates what angle the front wheels are at, and the rate of turn of the wheel- data required by the ESP system hence the ESP light. Coding will be required for any new unit -finiky job for the pros with the right gear MB dealer or specialist.
Hi Grober
Thank you. I thought as much but thought I'd get it out there and see if anyone knew.
Mechanic picked up on angle sensor too. Once again thanks to all who replied
Steering column module on a w204 is plug and play if it is a new part. I’ve fitted a fair few and never had an issue. A friend fitted a used one and had a lot of drama relating to the steering angle sensor in it, ended up buying a new one.
