p3mrl
Hi i recently bought a Clk55 Amg 2003 and there is a strange smell coming out of the air vents. smells of a burnt smell. any help appreciated.
grober said:Might be bacterial growth on your air con system if its been sitting a while. You can get sprays to treat it yourself or an aircon specialist would be able to sort it for a small charge.
p3mrl said:Hi i recently bought a Clk55 Amg 2003 and there is a strange smell coming out of the air vents. smells of a burnt smell. any help appreciated.
That sounds a bit steep but if it does the trick then you're sorted! When I had my aircon repaired last year the mechanic took all the filters out and blasted them with the antibacterial spray, it was like driving around inside a big tin of Uncle-Joe's for a weekp3mrl said:Hi all just got back from MB garage and said it was the air con and needed 'DEBUGGING' (bacterial growth). 1 can of Air conditioning Treatment should do the trick at £30.00 inc vat. Hopefully this works & might take a few days to clear. If it works i will let you know.http://http://cgi.ebay.co.uk/2-x-FORTE-TREATMENT-FOR-ALL-CARS-WITH-AIR-CONDITIONING_W0QQitemZ170036226243QQihZ007QQcategoryZ10374QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
