E320Trip
Well I am pleased to report that the sphere appears to be relatively easy to remove. I didn't notice that there was a sizeable space at the bottom of the bracket for this purpose.
I have loosened the two hydraulic lines successfully and loosened the sphere from the bracket. I have stopped there. I hope that I have sufficient clearance to remove the sphere without damaging any pipes.
The fluid that came out after loosening the pipes did look like a guinness foam (bottled Guinness I would say!) but settled to a clear if cloudy dark mild ale. Is the foam a conclusive indication of ruptured sphere membranes. I don't know if the sphere is actually gone but am willing to change it to see if there's an improvement in the odd lumpy ride at low speeds.
With regard to changing the fluid, I suppose it would be for the best, but I'm tempted to leave it in. If I was to drain it I'm concerned that fluid would remain in the pump and lines up to the ride height control. Can I turn on the engine and let the pump pump it out????
any tips would be appreciated.
