Tales of Woe
KwickWilly
Berkshire
SL350
Oh my God, what have I done! Not the first words that I thought I would ever be typing so soon after purchasing my dream car, but this is what I’m feeling after only seven weeks of ownership!
I purchased my very first Mercedes (2007 SL350) towards the end of March, and from an official MB dealership close to a hundred miles from home. After many months of searching this was the only official dealer that had what looked like a nice example with the right spec and close to budget.
I made the decision to use an official dealership as I know how specialised this model of car can be, and I wanted peace of mind when parting with a considerable amount of cash that both I and the car would get the level of service needed, and would hope for at least a year of trouble free motoring.
The first thing that made me aware that something wasn’t quite right, was an issue with the CD player on day three, where it just suddenly stopped playing and came up with an error on the Command “CD Player Unavailable”..!
The only way I could get it back on line was to eject the CD cartridge from the changer, and start again. This got it working again and so far, no further issues, so at the time, I put it down to bad tracking on the disc. Minor, I hear you say, but it gets worse!
Some days after this, I locked the car when it was dark, and noticed on this occasion the instrument lighting hadn’t gone out some ten minutes later, despite the car being locked, interior lights going out and mirrors folded in. Lock and unlocking still made no difference however, after switching the ignition on and off again and repeating the locking, this time it went out.
The next issue and probably the most scary, is with the gearbox (G7) and where I have witnessed on a number of occasions, shifting where it feels as if it is going from neutral to first and comes in with a jolt. This is most noticeable after cruising for a few miles on a motorway, coming almost to a stop then pulling away again sharply. The first time it happened, my partner thought someone had hit us up the back, that’s how violent it is with no exaggeration. All subsequent shifts feel fine and even this jolt may not happen again for days. The gearbox also whines a little in low gears, sounds a bit like diff whine but it is definitely the gearbox. It brings back memories of a previous car where I had a very similar experience and where the torque converter was on the way out.
In addition, sometimes when stopped, a brief second later you feel the gearbox engage and the pressure is enough to edge the car forward slightly. Both of the above observations occur in “S” and “C” mode, but more noticeable in “S”.
So, back it went to the supplying dealer who had the car for three days to check it all out. Well you probably guessed already, “Sorry Sir, we can’t find anything wrong and probably just the characteristics of the car”. They did however, conduct a full diagnostic, oil level check, re-programmed the ECU with the latest firmware and reset all of the user memory profiles etc, and it did feel better initially on the journey home.
Arriving back from the dealer last Wednesday (11th May), I didn’t use the car again until Friday evening to do the weekly shop, at which point the next issue came to light. On unlocking the car the key fob didn’t work! I tried the spare and that didn’t work either so reverted to manually opening the driver’s door at which point the interior lamps didn’t come on. When I put the key in the ignition and turned it on, there was a beep, the centre clock flashed and reset to 0:00, the dash lights flickered and the message “Convenience functions temporarily unavailable” came up. Looking at the owner’s manual I realised that this meant that the secondary battery was low and that the car had shut down a number of features including the ABS/SBS breaking feature to conserve power. Ever tried doing a hill start on a MB with no handbrake and the break hold feature not working? I wouldn’t recommend it unless you have a good four feet clear behind you, as this box does not hold!
Last Monday it was back to Mercedes again, but this time to a local outfit to investigate the new problems. I also reported that after this power problem, the gearbox was noticeably worse again, and asked if it could be related to fluctuating power levels that were causing the erratic gearbox?
The car was with them a full day and they said that other than the diagnostics showing low voltage levels due to the battery, there was no fault with either of the batteries once charged, the charging circuits were fine and within spec, residual current drain was also within spec and shutting down after three minutes was as spec so, no fault other than a low battery. I asked why this was as I had done many long journeys since I had had the car (2K in 7 weeks) and also less than 48 hours after doing a hundred mile journey at speed...!!! Surly it shouldn’t go flat in this time especially with two new batteries only fitted in January of this year? It is quite common I was told and I should boost charge it every week or so to keep it topped up, it’s a characteristic of the car!
Today, I did another long journey (250 mile trip) and whilst I have not had a power issue so far, the gearbox did jolt badly again when I came off of the M40 as I braked for the lights at the end of the slip road, then put my foot down when they changed, and once again it was like a shunt up the back.
Last but not least, there is more to tell and this time, more to do with dealer politics and profit over customer service.
Whilst going through all of the warranty and service documentation supplied with the car, I noticed that according to the electronic service sheet, the car should have gearbox oil and filter change at 37’500 miles, and which is independent to the regular service unless it is due. The car had done 36’864 miles when purchased, and in the opinion of my local dealer, should have been done before the car was handed over as it was so close. It wasn’t and they now expect me to pay a further £403 to have it done! Mind you, this has also come from a dealer that was quite adamant that any warranty work is only covered by the selling dealer for the first three months. Utterly wrong according to Benz-UK.
It is now in the hands of the supplying dealer to do the oil service, and I’m not that hopeful as they say it will have to come out of the sales guy’s budget, and he wouldn’t even pay for a set of wiper blades when I complained that they juddered like hell. They still do by the way at £60 a pair for genuine MB.
So you can see, my dream has been shattered, a car that is proving unreliable with faults that are difficult to diagnose, reluctant dealers that now have my money and want to make more, the ongoing thought that this car is going to be nothing but trouble, a rough changing gearbox and the real feeling that I have been well and truly hustled. Not the experience I expected from a car which was in excess of £60K when new, and bought used from a manufacturer that prides themselves on their used car quality.
I will let you know what happens and will no doubt end up liaising with MB directly but in the meantime, can anyone offer any reassurance, especially with the gearbox?
Many thanks
KW
If it's from an MB dealer, isn't there the 30 day exchange plan?
It applies to MB Direct so maybe to MB dealers too?
is possible to reject the car and have a refund - ask trading standards.
I was going to suggest the very same thing seeing as you havnt had the car for all that long.
My cousin has a 55 plate BMW M3 and that sometimes does rough gear changes or is a bit harsh when you set off, but according to BMW AND alot of M3 owners thats just a "characteristic" of the car, so it MIGHT be a thing with Merc aswell, maybe . . . . .
On the other hand though my mate has a BMW 530 diesel and that does exactly the same as yours when setting off, seems like someone has hit us in the back, but thats a known common fault on them gearboxes and if you spot it early enough then its a torque converter, otherwise its a new gearbox. Unfortunately he's just had the gearbox replaced. Its a well known common fault for them gearboxes used by BMW, and also the identical gearboxes used by Jaguar with the identical faults, yet neither BMW nor Jaguar will admit that its a common fault.
I seriously hope thats not the case here, but either way i'd be looking at getting advice from Trading Standards or atleast Citizens Advice Bureau.
Sounds to me like the gearbox oil needs changing.
The rest of the niggles just need ironing out, in my opinion...
Did you get a tier 1 warranty?
The gearbox problem sounds very much like one I had in a C320 W203 with the 7G gearbox. It only ever did it the once, in Germany after some (relatively - not vmax) high speed driving. On slowing gently it changed down, I think from 2nd to 1st or something similar, and I got a violant bang and the jolt that you mention.
I did mention it a week later to the MB dealer in Doncaster, who wanted to look at the car. I had a call to say that they had drained some gearbox oil, and it was burnt. New gearbox required.
Sounds like some pressure on the dealer, and a proper investigation into the gearbox may be needed.
You have had a horrible experience and it is easy to do things wrong and keep doing them once matters go off the rails.
1. A formal letter of complaint in neutral language to the dealer and copy it to MB UK (find out who the current CEO is and make sure it gets to that desk and no other. Set out in the letter, the sequence of events in an itemised list, ensuring you list every fault you require to be attended to.
2. Request a courtesy car and make it clear that it will be at the dealer's own cost while they take the time they must have to repair your car.
3. Give the dealer a reasonable time to investigate the matters which you are complaining about, so 5 working days of workshop time should be sufficient to detect all of the problems. Never accept faults as being characteristic of the car unless they are faults which are designed into the car deliberately and are widely publicised as being programmed into the car during manufacture.
4. If none of the above bears fruit, involve trading standards and complain that the car was not of merchantable quality and you want all of your expenditure back and to return the car as unfit for the purpose for which you bought it.
5. If you are desperate to keep the car, I would suggest that you speak to those nice people at MB Milton Keynes about taking a look at it and seeing what they can do. Every time I have phoned or called to the premises. I have been treated like a valued customer and their customer services element is outstanding. My indie was adamant that a limp mode issue on my C220 was going to cost at least £500 to investigate and repair. MB Milton Keynes found the issue within 5 minutes of opening the bonnet and repaired it in an hour. I was on my way with the hour's labour and a new sensor for a total of £128. Another impressive thing is that I had just pulled into the car park and was looking for a suitable space, when a person came up to me and said we were expecting you and told me who to see and where to find them in the building. It has spoiled me now and I know it wont be the sort of service I get from my Indie garage.
My words of advice on this are:
Don't procrastinate about this.
The above advice is sound, but you need to act, and act right now. Any delay is going to risk adversely affecting your case.
Good luck, and I really hope you get it sorted. A sound SL is a lovely way to get about.
I don't get Mercedes used warranties?
Surely if you buy a car from a main dealer you get 12 months warranty which acts exactly the same as if buying new?
You do with every other manufacturer.
What is all this tier 1 crap??
I would reject the car, then when they say they have 3 chances to get right give them those chances, don't give them 3 chances after it has been seen a few times, do it now.
This is so spot on it deserves to be quoted.
But ACT NOW especially as you seem to be racking up a lot of miles.
A car as complex as an SL needs a battery in pristine condition anything else is going to give any number of weird electrical faults like you have already experienced. You may have something that's causing a parasitic drain on the battery when parked up. These cars are notorious for this and to be fair its sometimes very difficult to trace an intermittent fault like this.[ its why frustrated owners give up and change cars!!!] I think all owners of SL's of this vintage ought to be issued with an intelligent charger to use since its almost mandatory to avoid low battery voltage electrical problems. With the increasing complexity of modern Mercedes there's a strong case for moving to 24 VOLT systems. Can't comment on the gearbox issue except that it seems to be intermittent also sorry. You could I suppose try contacting the previous owner to see why they sold the car, which might give an indication if these problems existed pre sale?
Thanks to all for your replies.
To answer some of the questions, I did receive the 12 month warranty and as I have now had the car over 30 days, I have lost the option to reject through the MB policy however; this doesn’t exclude trading standards as mentioned, so I’m keeping a strict record of the issues and the responses from the dealer.
In all fairness to them, the supplying dealer has been very supportive, and we have arranged this morning to have the car returned for a gearbox oil and filter change FOC. They will be having it for a week and supplying a courtesy car FOC for the duration, so that they can look into the issue further.
Many years ago I was a Master Tech for BMW, specialising in electrical/electronic systems, so I understand how difficult it can be tracking down issues like I have experienced, but as I love the car, I only think it right to give them the opportunity to resolve before I take it further.
I also looked into the service history of the car via the MB records, and these corresponded to the paperwork that was supplied with the car, no gaps and no mention of any previously recorded issues, and no accidents.
One thing that I did find out was that the car originally went into group stock back in January before being transferred to another branch mid Feb. In Jan it had new batteries fitted, what’s the betting they had a demo, batteries were orginal and low, fitted new (usually only part charged), got through the demo then forgot about it, resulting in it being sold on to me with it being only part charged! Who knows?
I will let you know how I get on.
Cheers
KW
Sounds like your dealer is being fair. Good luck!
Sorry to hear about the issues - hope all is resolved swiftly to your satisfaction. The M-B Tier 1 warranty is superb ... basically the same as the orginal 3 year one.
All the time, as neither of ours (both autos) have brake hold! Left foot on brake, right foot on accelerator :)
Some have asked to see some pictures, but I dont have a tab for creating an album. This may be due to being new?
Will follow up when I have more posts :)
Regards
KW
