hotrodder
Cheers. I'm guessing the tube is currently 5/8" 14swg (15.88mm x 2.03mm)? Are you using ERW, CEW (aka DOM) or CFS 3 (aka CDS)? I'm guessing ERW as CDS should be easy to source in 15.88 x 2.64mm. CDS is obviously more spendy than ERW though with CEW somewhere inbetween
Cold Drawn ERW Tube (CEW) | Hub Le Bas will give you sizes of CEW available (not so many stockholders carry CEW though), similar pdfs for ERW and CDS on that site too
I'm guessing that if the rod end doesn't have to be 1/2" for other reasons that size was chosen as it's closest to the tube ID i.e. m14 would leave you bugger all wall thickness and all pitches of m12 are in the 10.something range for tapping which'd work great if 14mm x 2.0mm tube was easy to find but off the top of my head in ERW it's not commonly available with a wall thicker than 1.5mm
