The other day after washing ML with Zymol auto wash as usual, on running my hand over the bodywork, I was dismayed to find it was covered in tiny spots of tar (even the mirrors). Ah, I thought, this is the chance to use the Xymol Cleaner Wax ( removes small blemishes etc, it states on the container).
However no amount of rubbing removed the tar spots. Then I tried Autogylm Radiant Wax- which worked a treat and with no real effort. Seeing I had the magic Zymol cleaner wax, I thought I would try it. It was easy to apply and remove until following the instructions, I sprayed a fine mist of water. This time round it required a tremendous amount of effort to achieve a decent smear free finish. While I love the smell of Zymol, I am not sure if I will rush to use it again especially as it is recommended to repeat the exercise 3-4 times a year. So there is no promise that the finish will be long lasting. Is there a better way of curing the tar problem?
