DamoC43
Wondering if anyone can advise.
I've a fault on the car (C43 S205 2019) which i believe is most likely caused by a damaged wire(s) somewhere in the loom to the front bumper loom. I've had to join some broken wires back together using solder sticks on this loom. I want to be able to test for continuity from the front bumper loom connection plug, which clips onto front bumper, back up past the repair work. The only way i have of doing this at present would be to cut the wires nearer the car above the repair and test for continuity back at the front bumper connection plug. This is something i'd like to avoid if possible since it will result in even more repaired wire joints on wires that already have a repair.
I was wondering if i could perhaps locate where this loom (Front parking sensors and pedestrian protection sensors) terminate at a fuse box location? Or is there some other non destructive way i can perform this test? wire pinning?
Many thanks
Many thanks
