WDB124066
- Apr 17, 2009
- 1996 E320 Sportline Cabriolet x 2
Brake discs (even good-quality ones) suffer a very-hard life.
They are constantly being heated-up and cooled down in a very short space of time - The heat distribution is often severe and uneven - The thinner they get, the more extreme is the thermal fatigue that they endure.
Perhaps we should be surprised that they don't crack more frequently.
Other real problem is that a very-large proportion of brake discs in use today originate in China (no matter what label they carry).
Some of them are utter rubbish.
I fitted a set of front discs to a Jeep Cherokee not too long ago.
They looked horrible when I took them out of the box.
So much so - That I ultrasonic tested and dye-pen tested them before fitting.
They were not obviously rejectable, but their surface was a variable colour - Which is not a good sign on machined castings.
I fitted them with usual care - New pads at the same time.
Twelve months (25k miles) later, the braking was lumpy.
The discs were clearly disintegrating.
I got my money back on the discs, but needed to fit a new set of pads at my expense.
This has got me thinking here quietly I might just get a tech to MPI my rotors after every 1/2 pad of wear or so. MB customers can't really dictate what is made where, so we may well end up with bits from places we really don't trust too much = pays to check.
A hardness test every now and then will tell a bit about rotors, both new and worn, I might have a play one day....
I've worked on projects and I am sure you have too johnsco where sourcing from certain Countries of origin is expressly written into contracts as forbidden, bit like Israel when working in Arabic Countries - it just does not exist.
