AdrianRD6
Hello guys, i need some help or advice about my issue errors on my car.
1. The position sensor for the intake camshaft (cylinder bank 1) has a malfunction. the signal is not present. I try to disconnect the sensor located on top of the engine and plug in back but with no succes. The error it’s still there. I changed the sensor and surprise, the error it’s still there. It’s possible to not by that the sensor, can by an other sensor?
2. The learned value for the fuel injector (cylinder 3) has reached the lower limit value.
I try to recod-in the injector but the coding it’s not remaining saved up on ECU. I try to recalibrate all injectors with “Quick teach in of values of zero qwantity calibration” and it’s still there the problem.
~~The car is an e220 2016 2.2 engine w212~~
Somebody can help my please!
I’m allready tired trying to fix that. I spend enogh money on service station for the same result like mine.
