I’m sorry about that. My wife calls me Southern Boring Services.This is fascinating even though I only understand about 20% of the OP's posts ..
Perhaps Herr Volker Haag was moonlighting for OpelThe oil pump pick up seal has exactly the same issue on the Vauxhall 2 litre CDTI. Luckily it has a low oil pressure warning light, which when it goes on at around 100k miles 6+ years, you know you've waited too long and your engine is likely compromised already![]()
Yeah, Jake next door does taxi work. He’s seen that Vauxhall fault a few times. He bleats on incessantly.The oil pump pick up seal has exactly the same issue on the Vauxhall 2 litre CDTI. Luckily it has a low oil pressure warning light, which when it goes on at around 100k miles 6+ years, you know you've waited too long and your engine is likely compromised already![]()
I've had to replace that oil seal on my insignia taxi. What a ball ache! Took me half a day to remove the sump, a few pence for the seal and half a day to put the sump back on.Yeah, Jake next door does taxi work. He’s seen that Vauxhall fault a few times. He bleats on incessantly.
Technically they are more accurate perfect circle when assembled. Ultimately though they are probably cheaper to makeI love this old school talk of bearings, rods and oil feed! Not seen the words "sensor " or "coding" once yet! Keep it up.
Out of interest, what is the advantage of cracked rods over machined rods?
I think they (cracked rods) also give improved mechanical stability for the big-end cap joint.Technically they are more accurate perfect circle when assembled. Ultimately though they are probably cheaper to make
Not sure about the manufacturing cost but making a single forging, cracking to create the bearing cap and then finish boring the big-end may well have a cost advantage over forging a separate cap and rod, machining their mating surfaces and fitting precision hollow dowels.Technically they are more accurate perfect circle when assembled. Ultimately though they are probably cheaper to make
Pretty sure the CLS does have a saddle sump. WIS mentions removing both oil drain plugs to completely drain the oil.Some flavours of M113k do not have this issue, notably the CLS, E class etc because they do not have the double sump like the SL and CL.
Same on my 159....basically the same Fiat/Alfa/Saab/Vauxhall engine.. I got it done in about 3 hours....most of which was cleaning up and painting stuff while I was under there. The clue that it had failed was the oil warning display coming on for the few two or three seconds on a cold start up....due to air being sucked past that seal.I've had to replace that oil seal on my insignia taxi. What a ball ache! Took me half a day to remove the sump, a few pence for the seal and half a day to put the sump back on.
Thanks for the answer.I can see the advantages for the initial assembly of the engine but it must be a nightmare during rebuilds. The potential for a massive **** up must be great.Technically they are more accurate perfect circle when assembled. Ultimately though they are probably cheaper to make
It shouldn't be....in fact it might make it easier....you should never mix up caps and rods any way and with cracked rod caps you cant....they will only properly fit the rod they came from....and its really obvious if they are not the right one.Thanks for the answer.I can see the advantages for the initial assembly of the engine but it must be a nightmare during rebuilds. The potential for a massive **** up must be great.
Do pukka high performance engines ( ignoring AMG and BMW M chip tuned lumps) use these, or do they stick with old school?
I can see that the slightest damage to any mating surface by, for instance, dropping a rod or cap, would be a disaster.It shouldn't be....in fact it might make it easier....you should never mix up caps and rods any way and with cracked rod caps you cant....they will only properly fit the rod they came from....and its really obvious if they are not the right one.
