E300TD 1999 W210.
I've just bought new tyres for the front axle.
The tread on both original front tyres is Wearing out on the inside edge (nearest the engine bay).
The tracking has been checked and is OK.
Can the castor and camber be adjusted to stop this pattern of tyre wear?
Can I buy adjustable bolts (not fitted on this car) and how much?
What's a geometry check?
My mechanic friend says a proper setup - tracking, caster and camber - would set me back £45.
He said "It's better than wasting £30 on having just the tracking checked!"
Also, the shoulders of these tyres has worn more than the rest (there is 6mm in the central part).
Should I inflate the tyres to a higher PSI to get an even pattern of wear?
They are 29psi front and 32 psi rear.
The car never carries much weight -just me- and I drive like a grey-head.
Jonathan
PS would anyone like to explain castor, I can guess at camber.
Jonathan
