seany260
So I made a led flash code reader for the grandfather's e200. And here is what it brought up.
Pin6- 2,3,8 'SRS'
Pin10-8,13, roadsters soft top( not correct dosent add up)
Pin12- staying on constant?? ( infrared remote) is faulty
Only thing is the document that I'm reading off says that pin 10 is for soft top roof and this is a sedan! Has anyone got the correct document for the full list of codes on each control unit.
I did try pin 8 which I believe to be the injection system but later found out there is a whole sequence to activating it for reading any stored codes.
Have attached the doc I'm reading off, page 11 shows what pins do what.
https://www.google.co.uk/url?sa=t&source=web&rct=j&ei=9UcTVYq5D6S_ywOx-YKQDA&url=http://www.mbslk.com/files/artikel/r170_fehlercodes.pdf&ved=0CB8QFjAA&usg=AFQjCNGgOZdFXz8UuWrt2UklTS_kunPd_w&sig2=AytaE3s2TjqRviP_pZuyTQ
Pin6- 2,3,8 'SRS'
