Forgive me but I saw no mention of a Vickers type number accompanying this picture . What also puzzled me was the single colour red label whereas the dual pumps should have a red/green label and be marked with two pressures??? 110 and 150 bar
like this
https://i.imgur.com/AGnnSnU.jpg
Maybe the later pumps were different but the whole things a minefield!!!!! hence my advice to inspect any pump rather than go by the label alone. There should be total of 4 radial pump piston holders [ bronze?] in a cross configuration at the front of the pump housing altho they may be partially obscured by by the pulley.The pump should also have 4 ports 2 for steering[ supply and return 110bar ] towards the rear and 2 for the 4Matic [supply and return 150bar] towards the front
here's a couple of pics from the peach parts rebuild thread.. Its from a w126 I believe. you can see the two colour label blue/green - for the two pressures and the second shows the second pump pistons.the third the 4 pump pistons that bear on the eccentric cam in the partial stripdown.
http://www.peachparts.com/shopforum...-pump-rebuild-1-tandem-psp-starting-photo.jpg
http://www.peachparts.com/shopforum...psp-disconnecting-stupid-design-tensioner.jpg
http://www.peachparts.com/shopforum...uild-14-tandem-psp-spring-pin-cover-plugs.jpg
