- May 10, 2006
- Location
- Preston, Lancs
- S204 C220CDi Sport ED125 (Mr) Kia Picanto Domino 1.1 (Mrs)
Just make sure you plug it in the correct way round.
So if I keep the orientation of the fuse I take out? All so confusing! LOLLooking at those pics…
Plug it in with the red cable at the fused side of the fusebox - i.e. with the original fuse out, the red cable goes to the ‘dead’ side ofthe original fuse. If that makes sense.
Original vehicle fuse plugs in to the two connectors that are furthest from the red wire.
New circuit fuse plugs into the connectors that are nearest to the red wire.
N.B. Those two add a fuse connectors are different and can add to the confusion.
My brain has just meltedJust to confuse things even further :
Anytime i am adding something extra to a vehicle i just pick up the supply from an unused fuse connection in one of the fuse boxes , there will be unused constant live or ignition live in most vehicles that can be used.
A crimp on spade connection with an inline fuse pushed into the live side of a connection has done the trick on many occasions with no need to put any extra load onto an existing circuit.
K
