Ricky, I did actually check the sensor at the top of the rear drivers strut earlier and it's in perfectly (I just changed that specific strut but I know the strut works as I helped remove it from the donor car) so it's not that... I did think about one the sensors being faulty but again the car was doing this before I changed them and it did work perfectly after I had changed them (for a day)!
I don't know if it's the pump as the passenger side works on the button up and down PERFECTLY and the red error never appears, just the blue one. Even if I pump the suspension up and down for 50 cycles it doesn't come up with any errors at all until I drive it at 30mph. If it had low pressure wouldn't the red light come up? Also that wouldn't explain why the ride height on the passengers side doesn't go as low as it should?
Thanks for your help as always, it's massively appreciated! I think I just need to get it scanned properly...
