Vito 109 2012
Emurray89
Vw caddy
Tempted to by a vito 2012 109 from a friend.
It has just had a recon block flywheel and new injectors for some reason the crank broke at 92000
Does the 2012 models still suffer Black Death injector seal failure? Any reason for why the injectors went and crankshaft snapped?
Cheers
Hi there,
These Do not suffer injector blow back like the earlier models, but they do have injectors fail causing hydro lock causing bottom end failure, I'm pretty sure we're on injector spec 3 now. Which has seen a near stop to injector failures
