Vito 639 no air con
takeaflight
Vito traveliner, ml, 107 sl
hi guys wondered if anyone can help, no air con, bought a top up kit, no reading what so ever from gauge.
There’s less than 1 volt going to the compressor, checked fuse and voltage appears ok every where else I can check. No leaks that I can see. Changed the temp sensor, checked the dashboard control unit. Ran diagnostic, icarsoft, no fault codes however if I run the actual data in the heater, air con section, the data flashes up and then goes to 0 or NA.
I have exhausted my abilities, but I don’t won’t it to beat me. Oh one other thing when I was taking the dash to pieces under the tray with the lid I found the remains of the start of a mouse nest, but checked the wiring and can’t see any damage, the air con switch lights as it should, the blower resistor works.
Help
Cheers roy
