Rumpelstiltz
- Jan 15, 2008
I have tried the Bosch Aerotwin 24"/61cm retrofit blade on my S210 E320, and the U-clip mechanism works just fine.
The only problem with the blade is that it is 3cm shorter then the original stock one, and the last 2 cm on the end towards the window frame doesnt touch the window glass.
Moreover, the original stock blade, is 30cm from middle to right and 34 from middel to left - 64 cm in total. This is due to the 1-arm construction on the w210.
In my persuit to find a perfect fit Aero blade, that not only works with the stock U-clip closing mechanism, but also has the same 30/34cm characteristica as the normal blade, I've stumpeled upon the VM19 Valeo which is a 25"/63-64cm Aero blade.
Have anyone tried it, and can confirm that this finally is a perfect with for the w210 1-arm wiper construction?
Thanks :bannana:
Yours, Rumpel
Thanks :bannana:
Yours, Rumpel
