Today I took the whole fuel distributor/air flow plate off the car to do a clean up .
It’s was pretty filthy.
I gave it a really good clean out and put it back on the car . I also did a multimeter test on the potenometer and think this reading is off as from the YouTube videos it readings head past 5 when full depressing the plate and mine hits 2 then down to 1.
Watch "Potenometer reading " on Streamable.
streamable.com
Anyway It took a few turns to kick in but ran smooth .
Then my ABS light came on and instantly knew it was the alternator , got the multi meter out and was running at the battery at 8/9v .saw the leads at the alternator looks a bit fluffy , gave them a good wiggle and rev of the engine and boom , back to normal 13.7V
Could this be the problem with the car getting up to temperature and affecting the alternator and it’s connections ? It does have a squeaky bearing on start up .
Since that the car ran with the slightest kick ever now and again Uner load at standstill but drove absolutely fine and seemed to totally clear up. All good .
After that run I did have to take a couple of the fuel pipes off the top of the distributor as I missed a nut holding the distributor to the manifold. I put it all back together and started it up and it ran fine but the kicks came back under load at standstill in R or D. I took the car out for a run and it all cleared up . The car runs as it should . Spent ages in it after the run, in idle and under load at standstill but no more kicks or spluttering.
Sure is a weird one , I half think it could be blockage in the fuel pipes as it always ran better when I put injector cleaner through it.
Could it be alternator related? - I’m not so sure as I had all the lights and heaters on to check the draw but the car was fine.
Will see how it is later after cooling down and starting the warm up all again .
