Well I’m back and so is the issue , but 2 factors that have arisen are that the day it all kicked off again it was absolutely pissing it down, had to go through some horrendous puddles last week and the kicking and stalling started up .
So I spent the last week checking lines, air flow meter and fuel distribution again .
But same old, runs fine on start up and then crap at temp on idle and pull away .
But today , I had the car running at idle most of the day - idle was high but not stalling and realised the throttle micro switch wasn’t engaging, then realised something wasn’t quite right , there was no spring , and it’s not had one for quite some time , I don’t know how long but definitely late last year. Don’t know why that’s gone , but it has .
So found a spring that works and after a 5 min drive it settled, no stuttering and stalling .
So I’m hoping it’s just that spring, but because the car has been running all day I’m thinking something has dried out and it’s running ok .
I will be taking it through some serious rain and puddles again to see if the problem comes back . It was the same conditions when the problem first occurred and probably explains why it’s been so bad over our damp wet winter .
If it is the wet/damp conditions then I’m guessing the distributor/coil or ground connections need a good looking at .
Will report back once I’ve put the car through the rain again.
