Feb 21, 2007 #1 jpskiller Active Member Joined Nov 18, 2006 Messages 898 Location Preston, Up North! Car Wifes does anyone know if there is a way to tighten up front seat belts, dont fully retract, as if a spring is loose?
Feb 21, 2007 #2 Ian B Walker MB Enthusiast Joined Jun 7, 2003 Messages 7,668 Location Freckleton Car 300-24, saloon and coupe, E300 24 valve diesel estate Don't muck about with them is the only advice I would offer. Want me to do a search for one?
Feb 21, 2007 #3 B bolide MB Enthusiast Joined Oct 8, 2005 Messages 3,724 Location Brighton Car BMW E39 525 Diesel Touring I've had front belts that wouldn't retract due to loose trim inside the B-pillar trim. But i suspect that the springs in the belt are old & tired and need replacing. Which means a new belt unless you can find someone to repair the old one Nick Froome www.w124.co.uk
Feb 22, 2007 #4 OP OP jpskiller Active Member Joined Nov 18, 2006 Messages 898 Location Preston, Up North! Car Wifes Ian Id be glad if you could do a search its both driver and passenger belts, cheers
Feb 22, 2007 #5 TonyVianoAmbiente Active Member Joined Feb 4, 2007 Messages 626 Location Buckinghamshire Car W124 E300 Diesel 1995 I have the same problem with my 1995 W124 and would be grateful for information on sourcing and fitting 2X replacement front belts.
